what the difference between the low profile cards HD7450 and the 650
How much better will the nvidia be in CS6?
The 7450 is just a re-branded 6450, which is about as low-end as one can get; the Intel HD 4000 is nearly as fast a 6450. The GTX 650 will be much better, especially for the money. However, to throw a wrench in this process, the low profile 7750 can be had for a litte less, and the two are about even. It's going to boil down on how well CS6 can use OpenCL vs CUDA.
Personally, I'd go 7750, but I don't use CS, so I can't say for certain one way or the other.
To make things even more interesting
-this is for my school BTW
they got robbed by HP,..... $700....
I'm making a setup for sub700 for cs6 rendering
cs6 dosent use open cl so no point useing a AMD card
#1a1a1a ; font-family: Arial,sans-serif; font-size: 10pt;">Mercury Graphics EngineThe Mercury Graphics Engine (MGE) represents features that use video card, or GPU, acceleration. In Photoshop CS6, this new engine delivers near-instant results when editing with key tools such as Liquify, Warp, Lighting Effects and the Oil Paint filter. The new MGE delivers unprecedented responsiveness for a fluid feel as you work.
MGE is new to Photoshop CS6, and uses [u]both the OpenGL and OpenCL frameworks. It does not use the proprietary CUDA framework from nVidia [/u].
OpenCL support in MPE is permanently disabled on all released Windows versions of Premiere Pro CS6
(pre-release) cs6 had it enabled
Adobe decided to permanently disable OpenCL support for the shipping version of Premiere Pro CS6 for Windows.
Now anless thay renabled it again (there is a lot of chat about it on adobes open communtiy)
http://forums.adobe.com/message/5081691
Well, I'd go 650, given Adobe's shakey OpenCL support.
