Help please! new build!
http://ca.pcpartpicker.com/p/2y6TE
So this is my build and i have a couple of questions:
Is there any money I can save with this build?
Is 470Watts enough for this?
Will my old Nvidia Compaq X case fit all of this?
any cheap cases that will keep my budget under $550-600?
Is that RAM okay? (really damn cheap)
Please help I need some answers!
Thanks!
the pricing isn't always accurate on pc part picker so make sure to check the actual sites and factor in shipping...  idk about the case but other than that it looks OK. you could also save money by going with a r9 270 instead of 270x very little performance drop
It'll come down to my final budget in a couple of weeks thank you!
^^^ yeah its a scam lol just go for the 270 also what are you trying to do with your build? just gaming? with your budget i wont hurt to look at Athlon x4s like the 750k or 760k then pair it with a 270
look at this http://ca.pcpartpicker.com/p/2y7te
unlocked quad core and a hd 7770 with a case and power supply
the 7770 is still a valid gpu and can handle bf3 at medium 1080
