I upgraded my system from Fedora 29 to 30, and now when I try to log on, the screen is stuck with just a Fedora logo. I am able to use ctrl+alt+F3 to login, but startx does not work and I have no way of accessing the desktop.
I have disabled and enabled nouveau drivers to no avail.
I tried using recovery mode, and it just says my root account is locked.
Upon consulting the X.org log, it says NVIDIA: Failed to initialize the NVIDIA kernel module.
Any help would be much appreciated!! Thanks in advance.
Ran into this myself a few days back. There’s a version mismatch with gcc between what ships with f30 and what the kernel folks use to build the kernel.
Unable to determine the path to install the libglvnd EGL vendor library config files. Check that you have pkg-config and the libglvnd development libraries installed, or specify a path with --glvnd-egl-config-path.
However, I already have pkg-config and libglvnd installed.
After running the installed, it gives an error:
ERROR: Unable to load the ‘nvidia-drm’ kernel module.
I don’t know how to paste the entire file as I am typing from another computer, but I found the lines
WARNING: Unable to determine the path to install the libglvnd EGL vendor library config files. Check that you have pkg-config and the libglvnd development libraries installed, or specify a path with --glvnd-egl-config-path.
->Driver file installation is complete.
->Installing DKMS kernel module:
->done.
GCC version mismatches are the number one reason for Nvidia installation failure.
It’s even happening on Ubuntu. bionic-updates updated to 7.4.0 while the LTS and HWM kernels are still built on 7.3.0.
If you run the installer with -A, it will list arguments you can run the installer with. if it’s a minor GCC version change, you can just do --no-cc-version-check. If it’s a major mismatch, then dnf downgrade is a better way to go.
Remember to check /proc/version BEFORE you update GCC. ESPECIALLY on Nvidia.
