I am building a pc and this is what I have. what do you think? should I change anything?
Looks good. I want that build
Well, you should get a Z87 board if you want to be overclocking. H87 chipsets don't allow for overclocking.
http://pcpartpicker.com/p/3fann
You are spending way too much if you are just gaming. You don't need an i7, 16GB of RAM, or an 850W PSU for a single GPU gaming rig and an optical drive? Ehh...
Intel Gaming rig for OCing:
http://pcpartpicker.com/p/3fatv
Intel rig with no OCing:
http://pcpartpicker.com/p/3faxu
AMD rig OCing:
http://pcpartpicker.com/p/3faA7
Even those could be made cheaper.
^ +1
yup, my thoughts exactly. Listen to this guy. your Rig was overkill. you would have been wasting money on performance you would have never seen.
thanks, i can save some money
my revised part list.
I went with the 750w power supply so I can sli the gtx 780ti later on
