Help Picking A New Case
I need a bigger case I can barley fit my gpu or my cpu cooler in it.I want a full tower case that has good air flow and I plan to go to water cooling in a year or so.It needs to be atx compatible.I have 140 to spend on a case.What would be the best case to pick or is there a better one in my price range that I don't know about?
The Cases I am Thinking About:
Cooler Master HAF 932 Advanced
Thermaltake Chaser MK-1
Thermaltake Chaser A71
If it goes on sale I would suggest the corsair 780t its almost a foot wide its huge no space problems many spots for radiators you will be happy
There are a few really good cases that are normally more then 140 but are on sale or whatnot right now. all of these cases are ATX compatible and are roomy, I think all of them can fit 4 way crossfire or SLI and E-ATX motherboards if you move the pins around. To top all that off, all of these cases have good to great airflow and can accommodate custom water cooling systems or AIOs.
Take a look at the following: The Corsair Air 540, its a mid tower, but, it can hold nearly anything. Due to its cube like form factor the Air has some of the best airflow out of any case and is easy to work in. the NZXT H630 this is a full tower with good airflow, sound damping, lots of space, and lots of options. The Azza Genesis 9000 is just a little over what you might want to spend, and, owning one I have a few gripes; even so, its freaking huge, supports water-cooling, and looks really badass. Lastly, check out the Corsair 750D again its just a little bit more then you were looking to spend, but, it's a really solid case that can fit anything and supports everything.
have the chaser A71 and I love it (pretty decent dust management) for the most part for my next build I'm thinking of a Fractal Design Arc XL http://www.newegg.com/Product/Product.aspx?Item=N82E16811352035 for the simple fact that I that I can remove the hard-drive cages (kinda of annoyed of buying cases with big metal strips right after the main intake fan)
I've got a Cooler Master N600 KKN2 (No window, three 5.25" bays, no permanent glowy fan). I don't have any liquid cooling, but they really harp on how much liquid cooling availability it has. It's big enough to fit a reference 7990, so there's that.
