I built my pc about 8 moths back using the following parts
Amd fx 6300 (oc'd to 4ghz)
8gb Kingston hyper x ram @1600 mhz
asrock 970 ex 4
Corsair h100i
Gigabyte gtx 670
thermal take 80 plus gold 750 watt power supply
ssd, hdd etc
my friend was selling his gtx 670 which happened to be the same one as mine. I wasnt really looking to get into an sli setup but it was such a good price. so anyway i bought it and installed it. and after fiddling to get sli to work i thought everything was fine but i haven't seen really any increase in game fps or in the case of skyrim (with a ton of mods) i saw a decrease in performance with 2 way sli. so i was wondering is there something that is bottlnecking the graphics cards somewhere
Hi there noob! welcome to the formus. that pc is problaby not bottlenecking anything. That fx 6300 will at most bottleneck ~3%, and other hardware isn't either (most likely).
your motherboard is the bottleneck for your sli config, because that chipset has a x16 lane and an x4 lane, which will reduce sli proformance a lot. You might want to consider selling that 670 and getting a 770 if you want that proformance boost that much. The sli improvement will problaby at most 50% if the game is scaled correctly, which usually isn't true.
to respond to you, it isn't 1%. If you want to see some real life performances, ask your friends that have tried. To be honest, you would lose 8~% performance with x16 x8 crossfire/sli, compared to x16,x16 / x8,x8. You REALLY don't want to crossfire/sli x16/x4, you would lose at least 20% in every game. And you really don't want to crossfire too much if you want to know. The scaling in many games are terrible, and with sli it isn't that much the of a difference. there's also the thing where, you know about how if the frames go pass the hz on your monitor? the screen looks as if the picture was off. Thats also what it looks like during sli/crossfire. In very special conditions do sli/crossfire actually beat a single card at the same price, and when they do, they generae more heat and power usage.
something you may want to try for skyrim is removing your ini files from the documents save games folder and relaunching it (assuming from steam) sometimes after upgrading graphics cards or configurations if you dont reset the ini files it will give values for a non sli configuration and thus running 2 cards even in sli mode the game will only utilize one card and you may be being choked for bandwidth which would explain the performance drop.
