I thought it would be easier to show you all than type in out, so I did.
http://www.youtube.com/watch?v=l6-pO-GWjBk
i7 3770k
Asus p8z77-V LE PLUS
H100i w/ Artic silver Thermal paste
i7 3770k
Come on guys i still need help :p
Hi,
You can try setting CPU load line calibration higher and/or more cpu volts. Only up the cpu volts if you can keep it cool enough (<80C in prime). Some of the ivy bridge chips overclock really well with very little voltage increase some need far more volts to get to 4.5 GHz. Hope that hels a bit.
Yea its the CPU LLC and Voltage Being on auto, set LLC to as high as it can go, and bump your voltage up step by step (dont go past 1.4v) until its prime 95 stable for at least 4 hours and you should be set.
