Someone please help me! I just built my first pc and I was messing with overclocking the video card and the screen went black so I turned it off and on again and it came on until it got to my desktop and it went black again so I turned it off and pulled out the graphics card and still nothing. It turns on as in all the fans start spinning and light up but nothing on the screen. Please help I'm freaking out over here
remove the watch battery from your MoBo
wait thirty seconds
replace battery
pray
boot
And what will it mean if it doesn't work
you broke something.
It still didn't turn on
What did I break
probably the GPU you were OCing
Then why won't it turn on without it
- DONT panic
- What mobo, cpu and gpu do you have
- What OS are you using and what overclocking software?
what are your specs?
I was using msi afterburner
Windows 10
what happens when yuo try to power the machine on - nothing at all or does it run but not output any video?
The fans light up and spin but no video onscreen
OK so you need to boot into Windows under safe mode, and remove the overclock you put on your card
Nothing comes on the screen. It stays black
even under safe mode?
It doesn't even pop up with the msi logo. I press power and then nothing happens on the screen
have you double checked that all power cables are plugged in properly, that the screen has power, and have you trried using a different output socket on your gpu?
