I’v been working on some software for a Intermec Ck30 hand scanner. I’m using an program called IBrowse (A web browser that has html tags to enable easy hardware scanning) to open a custom made html file. The problem is the memory gets dumped on every power off. Then when you boot the device back up, it recreates the memory from a “Persistent Copy” folder containing a bunch of “.~IPI~” files. I need to edit a couple of these files to have my html files written every time. Any ideas?
This is what notepad++ interprets the file as:
xœíV]kÛ0}ö
ÿAx¬°‡Ìv>6ÖÊýHY¶”6°—@‘e[Ëž¬$dÿhÿrW±šu´.ƒÒ‡bîÅ:çé^B¥ÁëWM€qXTB ÎT¾-:Uºÿ’f$ѺèÁµØøö¤Zt{žs2e“(—¤öíQ²0n?‚œôóÕ¨…eËî°Û)ÈX’-´ç>œËo°e~jaV"…cÇY~’ã’e½rYFLzïÍùtâ¹9aOàô:r÷œŸ±QÎÁ?bYq¢wE‰üNûÿRpûGÁ$Ï µ‡úGf‚h˜ó]=J¦™$ÌaåÛæ„ Mƹñ!/5y©w)j=›__Œ¯{çóéôôêf|Œ¢Ò”%Ø5æ92¾ñömŠY[ÁubfÀ}kÁ}ûtóÙ:Ay•T¤ª #NÚ€€†]áÖI)~¢‚‘ÝÜ rƒa,Q uÌ÷€:¸ÒѼftÊa¸dX’OQì“‚U·õÞU2A‘‰,Öš\±ï.{9J›±ï”ÎØFÄL©h-ë+Û°2R¢xò‡µüÁÝA›ñZ(Ç7[xNÝÿAÿª;v¯ù¸ÝMskÆçÍ–#¡‡ÑËùlq—þ"}×ôðõo½•AD%Ý1PRÇ ‚ƒqÝ«qè½k;µm£‘Wÿ ~GAð
It makes an html file named “scanmenu.html”
iBrowse
iBrowse Scanning 1) Scan Asset Tag 1) Scanner Input Page 2) ScannerNavigate Javascript Page 3) Scanner AutoTrigger Page Home © 2003-2006 Intermec Technologies
