Help on Upgrading! (Problem Solved!)
i have upgraded to a GTX 970 and a Corsair CS550M and i put everything in that is needed, i even cable managed
i made sure all cables were properly connected to where they are needed
the GPU was easy as i also already ahead of time DLed
now i try to turn it on, everything turns on but there is a beep somewhere, and i found it from the either the motherboard or the PSU
i need help as i am getting NO picture from any of the outputs
edit1: i did wash my hands and touched the Faucet quite firmly
NVM i got it, wrong 4 pin, it posted and windows
