when i turn on my pc i get to the starting windows screen (win7) and i get a blue screen flash and my pc restarts and gives me two options Start windows normally (blue screen) or start up repair (doesnt change anything)
Specs FX8350 Asus M5a97 r2.0 8gb 1333mhz Kingston KVR1333d3n9/4g
500 gb seagate windows 7 in ZALMAN z9 plus
Please help
After the BIOS but before Windows starts to loan press F8 (press a few times) then select Safe mood.
Does this load (dont worry it will not change or break anything just a simple addition of Windows to help boot and trouble shoot)
there is no safe mode option
did you do a fresh install of windows?
nope i had this hard drive in an old system, it worked fine
You cant just plug in a old harddrive with windows on it.
Windows dosent like hardwhere changes you need to reinstall windows fresh for a new sistem.
AH Tought so!
there is your problem, you need to do a clean install of windows
