Help on bottlenecking
Will I bottleneck my system if I use an E2200 and a HD 4850?
Ohh yes
Possibly.
i would imagine so. i used to have a pentium d 920 and an 8800 gts, it was a super bottleneck.
yes because im bottlenecking a phenom 9500 to a 9800GT
double post delete please
Yeah but it isnt a huge bottleneck. I would reccomend getting like a high end c2q or something, or if you going cheap get a q6700.
make sure your motherboard supports quads first, they tend to require a lot of power.
I've heard of bottlenecking before but never actually experienced it, I think? What exactly happens?
The cpu limits the gpu.. meaning you dont use the gpu 100%, because its being limited by a weak cpu
