Help on a mid range GPU
Wassup, Im new to PC gaming and have more or less got everything under control. Only one thing left, The GPU!
So the CPU would probably be a AMD FX-6350
I would like to spend around the £150-£190 mark ($210)
I'v had someone say these are the best but again its not helping me much.
GTX 760
GTX 660 TI
GTX 670 (on a budget stretch)
R7950
R7870
and the new R9 270x
Can someone give me some help
Cheers Guys
I would say for a match either a 7950 or the new 270X . I couldnt tell you about nvidia .
Cheers brudda, i understand like all the model numbers and how that works but its the bridge between AMD and Nvidia.
7950 other wise if you need nvidia go with the 760
I have just ordered one of these http://bit.ly/13QeXJU
(HD7950 £190)
Cheers man, That really helped!
