Help on a $515 build
I want to build my first gaming pc and I am on a strict $515 budget. I am currently turn between two builds. I intend to play skyrim modded (with an enb). So which build would have better performance? Also leave some suggestions if you have any.
Build 1:
CPU: FX-6300                                                        119.99
Mobo: MSI 760GMA-P34(FX)                                   59.79
RAM: Kingston Blu 8GB 1600                                   71.88
Hard Drive: Seagate Barracuda 1TB 7200RPM        54.99
GPU: MSI R9 270                                                    139.20
Case: Rosewill Galaxy-03                                          29.99
Power Supply: Corsair Builder 500w                          29.99
Optical Drive: Samsung SH-224DB/RSBS                 14.99
Combo        -11.00
TOTAL:        509.82
Build 1:
CPU: i3-4130                                                          109.98
Mobo: MSI H81M-P33 V2                                          55.99
GPU: MSI GTX 660                                                  139.99
TOTAL:        507.80
I'd take Build 1.  However, if you can get a good ATX motherboard and ATX case, it would be much betetere as the 760G is old and not really made for the FX series of CPUs.
Motherboards I recommend:
Asus M5A97 R2.0
Gigabyte GA-970A-UD3P
Asus M5A99X Evo R2.0
Asus M5A99FX Pro R2.0
ASRock Fatal1ty 990fx Killer
It's cheaper to get a 8gb usb stick and ditch the cd drive.
I don't think you'll have a playable (30+ fps) modded game with that video card but if you lower the resolution it will be fine.
Skyrim will run on high unmodded at HD resolution.
