i need help fast watch this http://www.youtube.com/watch?v=LNnO6YTejrQ i think this is from skype
thanks if you can help
I think you got that bitcoin virus that goes through skype. norton hasnt done an update to counter that virus yet, so I suggest getting malware-bytes and running a scan. it should find it and delete it. your laptop should be fine then
thank you
Glad to help
do i do full scan
yup. and make sure its an in-depth scan too with all drives checked as well as active memory.
