HELP: Noctua push pull 400RPM
Hey guys/girls,
For christmas i was given a noctua nh-u14s along with a noctua nh-a15 CPU fan to create push and pull. Having just installed it today i receive an error message on boot saing that my RPM of the CPU fans is at 400. I have tried the low noise adapter and removing the 'y' connector however nothing seems to work. I even changed my bios cpu fan settings and managed to get them to 500 RPM. I could really do with some help with people who really know what there doing, any help is much appreciated
Thank you
Joe
The noctua nh-a15 is a PWM fan and requires a 4-pin connection on your motherboard. Are you sure that it's plugged in a 4-pin connector? Worth a look.
Sometimes a noctua will not even spin the fans because they are so efficient disable cpu fan warning's in the bios (you get a warning by most mobos if a fan speed is bellow 800rpm)
cooperman is right! My motherboard flips out at lower than 800RPM so I turned off the reporting on the Noctua fans I run at low RPM. Awesome Holiday Gift!
We all should own the Cadillac of cpu cools well done guys. But really have your tryed removing the Low noise adapter?
