Help no boot :(
Yesterday i completed my rig
M5a99x evo r2
Seagate barracuda 1tb
Fx 8350
Asus gtx 650 ti 1gd5
Coolermaster 600w psu
Setup system
Booted
Installed all drivers
Installed bf3
Started playing
After 5 mins system shut off like sm1 has pulled the power cable
I started again and same happened again after 5 mins of bf3 gameplay.
Now i again started but this time it wont boot onlu cpu led blinks for splitsecond and nothing happens,mobo power led is green and gpu led is green too,remover psu supply from gpu,this time cpu booted but vga led and boot device led lights up
Turned off,help me i cheched all the cables are fine...my rig is not even a day old...
maybe you psu cant handle the cpu under load.
But it should boot,i mentioned i installed win and al the drivers.if psu was insufficient why would computer boot first time?
You could have a 250w PSU in your computer and it would boot into Windows (but for the love of Valve, don't do that). As long as you don't run something like Battlefield 3, your computer would boot up and function normally.
That PSU seems sufficient. There isn't enough information given for us to really help you, though.
We need a list of EVERY piece of hardware in your rig. Right down to the case fans. Have you done any overclocking? Are you running any type of liquid cooling solution? Are all the appropriate power connectors plugged into the appropriate devices? Check for loose connections. Run HWmonitor, and check your idle and load temperatures. If your rig bluescreens before it dies, grab NirSoft's BlueScreen View and see if it's software related.
I could go on, but something up there should get us a bit further.
cpu cooler installed correctly?
<body><p>no im running stock cooler at stock clocks as i said i just installed the drivers and bf3..now my pc isnt starting,i have haf 912 case which comes with 2 fans and they are only i am using,as soon as you press the power button i see 1 split second blink on cpu led(red) and nothing else happens,no sound,no fan spinning nothing,other lights stay green 1 mobo power led and 1 gpu led,but as you remove gpu 4 pin power cable,system starts up,strange btw gpu is asus 650 ti non oc non dcu2 just simple one....i hope this info is sufficiend and lastly psu is cooler master thunder 600w.
<body><p>can any1 help me with it?
sounds like a faulty psu to me 600W 80+ bronze will be enough.
