also my dad is a programmer so that might help you understand what he wants to do.He's made motorstorm and wrc series on playstation also if that helps with the build aswell.
IwinFTW a AMD A10-5700 IS A AMD Athlon II X4 750K (with disabled intergrated video core makeing it cheaper) you made a worse computer same chip useing a hd 7770 is more powerfull.
cons 1333mhz memory controller 125w's old cpu instruction sets
Athlon II X4 750K pros 1866mhz memory controller 100w has a 4ghz turbo speed overclocks like a boss (near 5ghz reported on air cooling) new cpu instruction sets amd piledriver architecture its dam cheap
cons its not realy a true quad core (bulldozer modules)
What can I say, I'm not much of an AMD guy. If my APU option is worse then definetly go for an Athlon II X4 750K. Ignore my post, then.
Was I wrong with the FX-6300 as well or was that actually fine? I don't really know much about AMD, so you guys' experience would be great here when I help my friends etc.
7850 Seems to much for what he wants to do.He said he would be happy with a APU system and seemed quite set on it ,i will see which of the builds he prefers.
