Hi guys i need some help.I built a budget pc at the start of this year here are the specs
ASROCK FM2A75 PRO4 Motherboard
Corsair Builder series cx 500 watt ATX/EPS 80 PLUS BRONZE POWER SUPPLY UNIT
G-SKILL 8GB RIPJAWS X DDR3 2133 DUAL KIT RAM.......And ofc the apu......
AMD A10 APU RICHLAND 6800K
And i was wondering what graphics card i could use to get a boost .I know you can crossfire this APU with 2 different cards one is the 7750 my question is should i go for the 7750 and what difference would it make to my overall experience with games .Or is there a card around the £100 mark that would be better than the dual graphics combo.Basically i am asking what card around the £100 mark is the best possible for my system . Thanks in advance.
