Its this pc good for gaming?
Motherboard:ASUS Sabertooth 990FX R2.0
CPU:AMD FX-8350 4.0 ghz box
Memory:Crucial Balistix Sport 8gb 1600mhz Dual Channel Kit
GPU:Sapphire Radeon HD7870 XT WITH BOOST 2GB DDR5 256-bit
HDD:Western Digital 1TB SATA-III 7200 rpm 64MB Caviar Blue
Case:Segotep Raynor Tower G1R Red
Source:Seasonic S12II-620 Bronze 620W
Cooling:Thermalright True Spirit 140 (BW)
Web surfing and flashed games at best.
Ok.....................That was weird.So for PC Gaming(BF3 CRYSIS3 MW3 SC2 etc) its good?
Idk man, sounds like you would have problems even running club penguin.
Its better with an 3570k?
that board is a waste of money for a gaming rig imo
so the asrock 990fx extreme 4 its better?
why do you need a 990 extreme to play video games on?
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130637
you wouldn't notice the difference between this board and the ones you picked unless you were trying to achieve high overclocks
IDK... youtube might even be a struggle with those low specs you need a 7990 or a titan at least, to play on low settings...
all joking aside you have a pretty cool rig specs, although im sure others will chime in with other options..
I want OC but at least whats a good motherboard that specs(and if i buy a cheaper motherboard should i buy with the rest of the money a watercooler?)
you can still OC with a cheaper board. If you plan on OCing the CPU get a aftermarket cooler doesn't have to be a H100. anyway buy what you want these are just my opinions
CrossRO your build is fine. most of the people posting above are trolls. personally i think you can get a topnotch air cooler and do as good as water. if you must have water cooling do not get anything smaller than a h100.
Thanks looming im going with the sabertooth and the thermalright cooller and maybe in the near future a h100
yoiu could try and save some money on the board and cpu cooler by not overclocking at all (or very little) and using the stock heatsink and fan and upgrading to a 7970. again just my .02$
The 990FX Extreme4 is fine if you what to over clock a little BUT it dosent support the FX-8350 out of the box it needs a bios update to support it.
You need to find out what revison and bios vershon the mobo has before you order it or you may be stuck with a mobo you cant boot with your chip
sounds good,have fun putting it together.
