What I want is exactly the first command but I want to be able to specify the input interface and the output interface. (I want to make sure that the entering traffic on a multi-interface situation to always be redirected to the same interface it was inputed from).
-t is the target table in this case "nat" -A is append in this case append to the PREROUTING chain -p is protocol here its "tcp" --dport is destination port ,"80" in this case -j is jumpt to target , target here is "REDIRECT" --to-port is pretty self explanatory
in the second command you have -i etho -i is interface, eth0 in this case -m is match , matches tcp in this case
in the 1st statement all local (?) tcp traffic to port 80 will be redirected to port 3128 (i think, not entirely sure as you have not specified a source network eg: -s 192.168.x.x/xx )
the second will redirect all local (?) incoming tcp traffic on eth0 and on port 80 to port 3128 (again no -s specified). https://www.karlrupp.net/en/computer/nat_tutorial has a nice little writeup on this.
i am not a iptables guru, just know a thing or 2 (and that may be wrong as well)
Almost right, all nat'd traffic with port 80 as it's destination will have it's destination changed to port 3128 in the PREROUTING chain of the nat table, i.e before the kernel decides what route to send it down.
The difference between -A and -I is very important in iptables. A good example is where your last rule in the chain is "DROP". If you append a rule after that using -A it will never be read as the rules are read sequentially. With -I you can also specify the line number to insert it above eg:
