Hello there.
I’m in need of advice regarding my local network.
My home is not particularly small and articulated on more levels. I already had set the network up in a crude way, but I want to tidy it up. Te need for this cam up due to issue with printing from some computers and my roomba loosing its position from time to time.
I have some hardware on hand that includes the modem-router provided from my FTTC ISP, a FritzBox 7590 modem-router that I’m currently using as a switch/extender, two Unifi wireless repeaters, a couple of older spare TP-Link/Netgear modem-routers for ADSL/FTTC, three TP-Link TL-SF1005D 100 Mb/s switches.
The ISP currently only provides up 100Mbps down 20 Mbps up on paper, about 55Mbps down 20 Mbps up typically.
My current network setup is the following:
TIM ISP Wi-Fi 5 router → Main floor WI-FI network 1
- FRITZ!Box 7590 → Main floor WI-FI network 2 (same name and password as WI-FI network 1)
** My personal laptop connected either via 1 Gpbs Ethernet USB-C adapter - Main-floor TP-Link 100 Mbps switch
** Epson printer
** Unifi Wi-FI module → Second floor WI-FI network
** Basement TP-Link 100 Mbps switch
** ↳ Unifi Wi-FI module → Basement WI-FI network
** ↳ HP printer
** ↳ A desktop computer
As you can see, the network is a mess. At the mooment, the main issue is with the main floor having two different networks with same name and password. I don’ t know if they currently work as two access points to the same wi-fi networks or if the two network actually enter in conflicts. It may be the reason why the roomba gets lost, lately.
I want to tidy up and my main objectives are:
- Unify the different wi-fi networks so that any device can seemlessly switch between access points and stay always connected on the network, in particular for smartphones and my roomba
- Be able to access every other device in the network from every other device unless each individual device is set up in a way not to be accessible (e.g. for privacy reasons)
- Be able to print to the Epson printer and possibly from the HP printer from every device in the network
- Have the network configuration resilient to general blackouts and to blackouts in specific parts of the household: if the light goes out, when it reboots it needs to remember its configuration. It doesn’t mean that the network needs to be up when a general blackout happens, but has to be online when, for example, the electricity is abruptly shut off in the basement.
- Have the network (relatively) easily upgraded in the future (FTTH is in sight, Wi-Fi 7, 10 Gbps Ethernet…)
- Be ready for a future NAS addition
- Make it possible for a specific computer to be made accessible via SSH from the outsidem, and have its MAC/IP static so that if the light goes out or the network needs to be rebooted, the specific computer can be accessed again with same information as soon as the network is back up and running
- Easy connection procedure to the wi-fi network
The constraints are the following:
- Reuse as much of the available network hardware and possibly buy no additional hardware
- Limited space for wiring in the walls, so for example only one wired connection to the basement (two floors down) is possible.
Can you help me learn how to set it up, both from an hardware and software point of view? Thank you very much
