Help Me? please
I am switching from console to PC gaming and I got the specs from the $600 teksyndicate build, but I wanna know what games it would be able to play and how good it will play them.
For example how good would BF4 play??
Here's the link to the build
https://teksyndicate.com/videos/kill-your-console-build-2-600-gaming-pc
I'm using GPU option two
Bf4 you will probably be able to run low to med seetings with desenct team rate I would save the extra buck and get the other GPU and u will be able to stay around med settings for sure
Since Battlefield 4 is implementing mantle, I'd go with the "new" R9 270X, which supports mantle
http://pcpartpicker.com/p/1WzBD
CPU is relatively newer and faster.  And cheaper now.
Ram has similar specs.  Pretty much should provide identical performance
Case is a great budget case.
