:( help me! please
oh thank you for clicking this .. im having a hell of a time figuring out which to put in a new build.. either a amd a10-5800k or a amd fx 8350
PLEASE HELP if you have any info thanks a bunch.
it depend on your buget if you can get a amd fx 8350 than go for it it a better cpu make sure to mach it whit a good gpu but if your on a buget then the a10 5800k is awsome it has good intergrated grafique but what are you going to use this pc for apu are know to be good media system and buget gaming pc it realy come down to your need and your buget
