Help me pick my graphic card
    I am looking to upgrade my graphic car in my system. Right now I am running a Gigabyte GA-Z68XP-UD with a I7 2600K and 16gb of ram. I have a EVGA 660 and was looking at a 760 or a 770. This a dual boot system with windows, OS x. I am getting away from console gaming. I need a card good for video/photo editing and gaming. I am a long time tek watcher and first time poster. Any input would be nice. Thank you for looking.
Budget?
I guess 770 or r9 280X would fit in your budget limits
The 760 is not much of an upgrade over the 660, especially if you overclocked your 660 (which you should be doing)
The 770 will be a good upgrade, but it is an expensive card. If you are able to, I recommend waiting for the GTX 800 series to come out, the 700 series will then see a large drop in price.
There are no new demanding games coming out any time soon, so the 660 should handle pretty much all current games decently.
Sli ?
I dont really know ... a 660 sli would give you amazing performance but you might have problems with the dualboot.
Wow, thanks for all the info. My budget would be around the $400.
