I seriously need a Good Video Card! I posted my PC Build on another post, and majority said to get a better GPU.
Here is my Build it costs $476(without GPU) I am aiming for $600-$630, so the GPU has to be $120-$150
CPU : AMD Phenom II X4 965 Black Edition Deneb 3.4GHz Socket AM3 125W Quad-Core Processor HDZ965FBGMBOX
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
Mobo : ASUS M5A97 R2.0 AM3+ AMD 970 SATA 6Gb/s USB 3.0 ATX AMD Motherboard with UEFI BIO
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131873
Memory : CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ8GX3M2X1600C8
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233255
CASE : COOLER MASTER HAF 912 RC-912-KKN1 Black SECC/ ABS Plastic ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119233
HARD DRIVE : Western Digital Caviar Blue WD5000AAKX 500GB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136769
POWER SUPPLY : CORSAIR CX Series CX750 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS BRONZE Certified Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139040
DVD : ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner - Bulk - OEM
OTHER : Rosewill RCR-IM5001 USB2.0 75 in 1 internal Card Reader w/ 3 ports USB2.0 Hub / eSATA port / Extra silver face plate / Molex ...
http://www.newegg.com/Product/Product.aspx?Item=N82E16820223108
