Help me on my build
So I'm new to computers and I'm building a first time gaming rig. I started with logan's 350 dollar rig and changed a few things. these are the specs
http://pcpartpicker.com/p/pdqc
if you guy could help me suggest things that'd be great. I was thinking about downgrading some parts and getting a graphics card. I'd like te price to be sub $400 and ill I've using it for mmorpgs like Swtor and TESO when It comea out. dont want like perfect graphics just for it to run smoothley and less load times. Don't know what to do about fans and CPU cooling so ya I need help on that
This might do you better.  Cheaper and got you a 1TB Western Digital
http://pcpartpicker.com/p/pgSH
I agree with Fox. Yours could have been good, but you picked a way too expensive case for the budget.
Would the difference in the speed of the ram be noticiable
Yes, very, very much.
I forgot to mention that in Fox's build
So I should just get a cheaper case and switch the internal hard drive to 1tb and ill be good?
Yes.  It's a budget build so you don't need an expensive case nor that fast RAM.  But, yes, get the 1TB WD Blue.  You'll be much happier with twice the storage
And I've actually found this [url=http://www.newegg.com/Product/Product.aspx?Item=N82E16817151119]modular 550W SeaSonic[/url] for only $5 more than the Corsair one, after rebate.  (This is the PSU I'm using for my build too)
Get this and the case now before the sales end.  The other stuff you can wait out a little closer to Christmas for better deals
Do Fox's build, but change the ram for faster ram. It's very important. In games, you'll see big difference in fps between speeds. Or you could buy the slower ram and oc them yourself.
http://pcpartpicker.com/p/pt7J  how's that
Yep. If you know how to OC( or you can research), then save some money by doing Fox's build with the NZXT case. Then just OC the sticks. If you don't want to go to the trouble, then yeah, that builds good.
As you can see here, ram speed is important for AMD APUs.
Ah. Well, then I would choose the 1866 after all, and that case looks very good too
But do get the SeaSonic. 50W more and modular for only $5 more
