I have a massive problem
2 months ago i built a pc and installed windows 7 professional 64 bit on my ssd
it was booting in under 14 seconds
1 month ago i turned it on and it was taking ages ( i waited an hour )
then startup repair came up and said loads of stuff
i checked the connections to ssd
and booted again and it was fine
yesterday i booted it and it was the same problem so i checked the connections and booted again :C it didnt work like before just the splash screen
so now when i boot it takes about 7-ish minutes on the splash screen ( the pulsing windows logo )
then it gives me the option startup repair or try booting again and i click the booting option and it boots fine ?????
this is a massive problem because it took 10 mins today which is longer
PLEASE HELP
( sorry this is a bit messy )
( this may be in the wrong place-sorry )
