Help me level1 your my only hope / USB C Cables 90 Degree left Angle
does anyone know if ther is an were to get a USB-C to USB A 3.1 Gen1 or 2 Cable that 1.5 ft ive got a need for one
or were i can get a USB C Cable to USB 90 Degree left Angle A 3.2 gen 1 or 2 at 1.5ft these would be for my laptop
Quick search and got this as a result:
right angle type c
Hope it helps!
USB-C can be flipped either way… so if you’re needing left angle on the USB-C, then a right angle will work the same.
If you’re needing a left angle USB A 3.1/2 Male to USB-C female with a 1.5 ft cord, then you’re likely not going to find many options. I’d discourage you from trying to buy the only result on Amazon or eBay as it’s likely crap. Any possibility of using an adapter (no 1.5 ft cable) and connecting a full length cable to the device?
If not I’d use a left angle USB-A male to USB-A female extension. Then connect an USB-A to USB-C cable to the device. But I wouldn’t use more than 1 adapter + 1 cable in the connection.
that might help, my reasons for needing such a cable are ive got this laptop from acer with the 3350u an its pretty good for the spec an ive dumped into it 32gb of extra ram an a 500nvme but the overall biggest bumper is the lack of ports an of course its a laptop an that the norm
but both me an my sis loved this old laptop we had 12 years age were the ports were on the back side
so now the closest we could get is low profile 90deg headed cables but on the acer 3350u ive got the problem with the usb ports are the orientation of the port means the 90deg right angle block the remaining usb 3.2 ports
which mean to use the right angle 90deg will block one to two of the 3 usable high-speed ports
71YVpcbSAlS.AC_SL1500
im got this an used velcro to the back of the screen an only need 1 - 1.5ft of cable to reach
which if i can find a short 3.2 gen 1 or 2 A to C say about 1ft all be able to connect the two via one cable to the side of the laptop leaving two free usb ports while having a 3rd hdmi an card reader on the back
id rather just two cables to pull this off an not have to use multi adapters
like this an this
id rather find if someone can point me to a link to something like this but be a 90deg left angle
3.2 gen 1 A to c
instead of a right angle 2.0 to c which i didnt spot at the time
