[IMG]http://i675.photobucket.com/albums/vv117/xXxPathogenxXx/wire.jpg[/IMG]
I have been working on it for over an hour
it was alot worse than this before
edit fixed resize
lol way better than mine
I need a better pic with better light, use a camera with flash but that blue cathode does not really help.
why the fuck is there a duck on your hdd bays?
Sonata wrote 4 minutes ago »
thats the intimiducker lol my sister put it there lols
put all the cables on the bottom, with the long ones around the back asnd cover it with duct tape
the6ftmidget wrote 9 minutes ago »
well do but too fucking lazy right now lol
and its the best i could do beucase there are ZERO cable managment holes
and to add to it the wires from the shitty psu are too short
i worked tooth and nail to get it that good
uhm.. what is too short?
GreenSLi wrote 1 minute ago »
before i got my 9800gt i had my hdd a slot higher when i added the 9800gt i wasent able to pluge the power for it with the hdd
so i had to move the hdd a slot down but the power connection for the hdd is too short its barley plugged into the hdd if you see the arow pointing the wire is liek this
| (wire)
-- | (gpu pushing wire)
| (wire)
Oh I seeee..
Drill a hole in the gpu, shoud make some space. Or make a hole to the backplate.
GreenSLi wrote 4 minutes ago »
Oh I seeee..
really? [sarcasm] a hole in the gpu i dont think my gpu would work any more
lol
get out the mr. dill and penetrate ms. case lol
could just get black cable sleeves and sleeve it. that makes it look neater without much work.
D3ATH wrote 52 minutes ago »
im trying not spend money because i down own a dremle nothing more than $45 bucks
and i dont want to take apart everything and put it back together i dont have time for all that
but im definitely going to get some cable sleeves can u link me to some please?
shove some cables behind the mobo tray, and loop the 24pin connector around the bak too
are there any sata power connection extensions?????
EDIT:
i found some here http://www.performance-pcs.com/catalog/index.php?main_page=index&cPath=348_89
but there are like a million dont know which one to choose
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=4024&Description=sata%20power%20cable&name=%240%20-%20%2410
