Help me fix my computer and I will worship you as a GOD!
*Major Update*
The reboot loop problem is fixed. The problem now is that whenever I open up a game the PC crashes and resets.
Problem:
The computer works for about 4 hours before shutting down then entering a continuous reboot loop in which it gets to the Welcome screen then starts over.
When did it start?:
The problem started when I entered Empire: Total war and changed the settings to high, then I went to a battle and the computer reset and continuously tried to reboot.
Important Notes:
It was recommended to me that maybe my hard drive was failing so I got a new one. The old one only let mestay on for 1 hour before restarting, this one lets me stay on for 4 hours before restarting.
Launching Crusader Kings II, Super Crate Box does NOT crash the PC        Launching Alan Wake, Counter Strike, Empire Total war DOES crash the PC
 The Intelburn Test ran fine on standard 10 times
however the second Furmark started my PC reset
Running OCCT GPU 3d test & Power supply test with my OLD GPU works fine, running OCCT GPU 3d test & Power supply test with NEW GPU it crashes in the first few seconds.
Specs:
CPU: AMD FX-6300 3.5GHz 6-Core Processor
COOLING: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler
MOTHERBOARD: Gigabyte GA-78LMT-USB3 Micro ATX AM3+ Motherboard
RAM: Crucial Ballistix sport 8GB (2 x 4GB) DDR3-1333 Memory
GRAYFIX: XFX Radeon HD 7870 2GB Video Card
POWAH: CoolMax 600W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply Seagate Barracuda
HARD DRIVE: ST1000DM003 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
 I have made a log of what I was doing/ how I tried to fix it over the last few days.
1/16/13
System restored to C++ Redistributable install
Still loops
System restored to DirectX
Still loops
System restored to League of Legends(A program installed several hours earlier)
Still loops
Computer Turned off during one of the loops on its own.
Turned off when Tried entering Safe Mode With Networking.
Regular safe mode occasionally wont work.
Turned off for a few hours (2-3)
Logs on normally 1st try.
Restart computer to update mcafee
starts looping upon restart.
1/17/13
Watched videos for 4 hours
Pc Turns off
Starts looping
1/18/13
Watched videos for 2 hours
Reset when opened game "The Void"
Successfully loged back on 1st try
Entered loop after being on for about 4 hours total.
1/19/13
Windows Service Pack 3 Removed
Reset to finish Install
Logged on 1st try
Opened game "The Void"
Doesnt crash on Splash Screens
DOES crash on main menu
(Same thing happens with other games)
Logged on 1st try
It sound like you may have a overheating issue with your gpu
It was working for several weeks before this started happening and the temp in the bios seems normal.
Check your temps...
Also try and remove your GPU, then have your system run a bit. Or remove one of your DIMMs and have your system run... We could rule those out along with your HDD as causing the problems if ever.
Then we can evaluate the other parts later on if the problem persists
Also, is your XMP profile set properly for your RAM in the BIOS?
I dont think I changed anything for the ram in the bios so that might be the problem
it is usually set properly automatically, but there are some boards that give the wrong clock timings. So it might be worth a shot just to see if the timings, mhz, voltages, were set right.
if it still restarts, then try and remove one stick at a time, let it run with one stick, and see if it still restarts. or remove your gpu and run your system. we could rule out those components at the very least...
I have no idea but I'm guessing either a power shortage or High temps
Or wait... I just noticed you are running an AMD processor; wasn't there a conflict of sorts with AMD processors and XP sp3 back in the day? Lemme look for the work around for that. Because my friend also had those restart loops and we found out it was XP sp3 conflicting with AMD processors...
Yes I noticed that as well but I uninstalled SP3 about an hour ago. Hopefully if it doesnt crash in the next few hours that means the problem was fixed. I also just restrarted my PC to get into the bios and didnt have any trouble getting back on.
I just checked the temps and the System is 30 Celcius and the Cpu was 37 celcius
Aite, just let us know if it still reboots...
If ever you do want to use SP3, you could watch this video that gives a workaround
http://www.youtube.com/watch?v=WjMOCXcNYaw
Or visit this site, which is basically where the video got all its info from
http://msinfluentials.com/blogs/jesper/archive/2008/05/08/does-your-amd-based-computer-boot-after-installing-xp-sp3.aspx
I'll be seeing your updates when I wake up LOL its like 1am in this side of the world =p
Good luck, mate!
alright thanks for the help, if it does reboot im gunna try your other suggestions from earlier
check your GPU temps as well, and run memtest
I ran memtest on one stick, im just gunna keep the other one out because theres no point in using 8gb on a 32 bit
I reformated the harddrive and reinstalled windows. Im gunna install everything one by one until I encounter the problem.
it's likely not related (but may be at the same time), coolmax makes bad quality PSU's and you probably should swap your out before it fails (here is a vid from hardware secrets https://www.youtube.com/watch?v=DVqv5-vgDXk)
Alright heres an important note that im hopeing somone smart will be able to figure somthing out from.
Alright this is probobly really important
you have gpu problem it might be drivers or overheating, it seem as soon you stress the gpu at it fails, check gpu temps and make sure have latest stable drivers.
