I just bought a machine to start playing around with, with the eventual goal to succeed my Synology NAS.
So far I have done quite a bit of reading, but am still not sure which system will fit my needs the best. Right now I am thinking abut TrueNAS Core, TrueNAS Scale, Unraid or OpenMediaVault. I am open to any suggestions, solutions for mentioned problems or anything else you might have to add!
I have written down some requirements and wishes that I have for this system. Also open for suggestions here.
I would prefer to be able to do all of the configuration of OneDrive Backup, VPN Server, etc within a GUI.
Hardware:
i5 6500
16gb RAM (on the way, 4gb to start with for the first few days)
Boot SSD
500gb HDD for testing, will be 2x(6tb-12tb) mirrored when deployed. Expandability would be nice.
Requirements:
Plex Server
VPN Server
Backup Onedrive â NAS (or sync in the future)
Snapshots or versioning of individual files
Docker (probably necessary for VPN and Plex server anyway)
Nice to have:
(automatic) Backup to USB Drive and other network targets (old Synology will then be used for backup) for backup purposes. Partial backups should be possible, as not all data is that important. Ideally with some versioning.
TrueNAS Core
-Expansion of ZFS not easily possible. Need to create new vdev with its own redundancy. Since I am starting with just 2 drives, this would waste a lot of space and end in a dumb configuration when expanding
-No Docker
+Great plugins
TrueNAS Scale
-Is not fully finished? What will be missing?
+Docker
+Are the same plugins available as for Core?
Unraid
+Great expandability
+Docker
-No Plugins for easy Onedrive Backup etc. Needs to be done in command line with rsync?
OpenMediaVault
+Plugins
+Docker
±Expandability?
-Backup of config not possible
Proxmox with TrueNAS
-Complexity of the whole setup (I am a noob and have not setup any of these systems before)
+Second VM with Docker support
Please leave any input that you might have on this. I appreciate the help!
