Help me convert old hardware into a home NAS
It wasn’t really that bad, just unfamiliar.
Oh, well… whatever… one person gotta do what he’s gotta do
FreeNAS has became TrueNAS CORE. Looks like the WebGUI has become waay better!
Don’t reinvent the wheel here. If you’re comfortable with OMV, keep using that. Storage needs to be robust, tinker on your other platforms. You almost certainly want ZFS, which means you may need to add an HBA (host bus adapter) rather than an actual RAID card if you run out of SATA ports, because most modern OSes will want direct access to your physical disks and the redundancy and other magic will be handled in software (versus RAID controller). Look into FreeNAS 12.0 (or TrueNAS as I think it’s new name) but it’ll want more RAM. Consider tiered storage (fast ssd cache on top of HDDs for volume storage), however this adds additional complexity. ZFS on Linux is becoming more mature, it may be ready for use in our homes, but ask someone much smarter than I (i.e. @wendell - I think he has video tutorials)…
Personally, I think you should run whatever distro you’re most comfortable with unless one of the aforementioned prebuilt NAS options are your cup of tea, heck even Windows makes a great and simple storage server if that’s your preference, but requires a license. MANY of your answers are contained here if you want to roll your own: https://perfectmediaserver.com/
Good luck with your fun project. Great use of hardware you already have on hand. Jot down your requirements and work backwards from there; total storage (plus future growth)?, ZFS?, physical disks layout? Redundancy? RAIDZ2
Actually, I haven’t been using OMV for a long time, so I don’t even remember how to set things up… if I forgot what a wheel is, then might also reinvent it…
…especially if I need to make changes to OMV to properly use ZFS (which I’ve never used before)…
And that’s why I was thinking of buying this, which is also already configured in IT-mode…
That said, at the moment I only have 6 100% working SATA drives on hand, and my motherboard should have 6 SATA ports.
I should be able to expand storage in the future, right?
Yes, it was already suggested to me and I was looking into that
I managed to get 2x8GB DDR3 sticks, so I should be runnin 12GB RAM now… is it enough?
Maybe in the future I’ll get a cheap SSD to put the OS on, but I don’t think I need caching at this stage.
At the moment I have an SSHD that should be fine to put in the machine, but that’s probably the most I’ll do.
I’ve been using Windows most of my life, but I’m switching more and more towards Linux, as it’s also what I’m using for university (I study Physics).
I still require Windows to run a lot of programs, but I have many Linux machines on hands, and I like to experiment with new distros, DEs and other stuff like that.
Setting up TrueNAS should be fun!
It would be nice if he could answer my questions, but I think he has more important stuff to do and I don’t want to annoy him.
Thank you very much!
Thank you very much. I hope to do something right and to share my experience.
I used to have a small Italian tech channel, and I’m thinking about publishing videos again in English, so that I can share my passion for tech and also train my English speaking abilities. It’ll be akward at the beginning, I guess…
Yeah… I have this hardware on hand that is working fine but that is worth nothing on the used market. I also have many computers and external hard drives around the house, and the files are fragmented everywhere, so consolidating my data on a single machine would be great.
I’m a cheap person, I have fun with tech and I care for the environment, so exctracting the best from this hardware for a cool project was a no brainer to me!
Alright, great stuff. You’ve made huge progress already. I would get a USB flash drive (or two), install TrueNAS 12.x onto that, which will then become your boot device moving forward, which you’ll need to specify in some way. That way, booting directly from USB stick, you’ll still have all six SATA ports available for bulk storage. What size are you disks, how many of each?
Regarding memory, 12GB will be a really nice boost from 4GB original (obviously 16 would be better, but i think that’s sufficient). I believe next step is to plan your drive layout into pools and vdevs.
Did you say you have 4 x 1TB & 2 x 500GB ? I would separate those, building redundancy into both, unless you just want a 2 x 500gb (1TB usable) for storing ISOs, etc. Lots to decide here, but you’re really close I think. Keep up the great work.
TrueNAS Core requirements are 8GB RAM minimum, so I’m at least above the minimum specs
At the moment I have 2x2TB (with possibly another coming), 1x1TB, 1x500GB and another one of which I can’t remember the capacity at the moment (it’s already installed in the old case, so I don’t have it on hand).
I don’t like the boot drive to be an USB stick: the boot time would be even worse than it already is with TrueNAS.
If I manage to get 3x2TB drives, I could set up RAID 5 on those, but other users here have suggested me that it’s not particularly useful with ZFS.
