Hey guys, new to the site, so I'm going to just go off the format provided in the guidlines.
First a little background: I'm not necissarily new to PC gaming. I've been gaming on my laptop for a couple years now. I have a Lenovo Ideapad with an AMD A-10 4600M APU with an AMD Radeon HD 7660G. I have over 100 games on steam and I'm really loving PC gaming so far. But with this laptop I can only go so far, most games I can play at medium settings for a semi-decent framerate, while games like Battlefield 3 I can only play at the lowest settings with about 20-25 FPS. So long story short, I'm ready for an upgrade.
- Budget. I'd say around 1500, possibly bump it up to 2000 if need be.
- Where do you live: United States
- No Retailer preferred, I like using newegg and amazon, but I'm mostly concerned about getting the best deals for the parts.
- I'm going to need peripherals, definitely.
- What will you be using your future computer for? Gaming, and I want to emulate using the Dolphin emulator.
- Do you overclock or want to get into overclocking? Its not a requirement for me but I'm willing to try it out if it will get me better performance.
- Do you plan on going for custom watercooling now, or in the future? For this build, No.
- OS. Do you need a new one? Yes, I plan on getting either Windows 7 or 8.1. I want to hear reasons why one is preferred over the other.
- What kind of settings do you like or what FPS do you want to play at? I want to be able to play most games at Max settings.
- What resolution will you be playing at? I would like to be able to play games at 1080p.
- What kind of games do you like to play? I like to play all kinds of games, I'm going to post a link to my steam profile just so you can see what I have, but I'm one of those gamers who likes to play a little bit of everything.
- What kind of keyboard do you prefer? Mechanical, LED backlit preferred.
- What type of mouse-grip do you have? Palm, claw, combination? I've never really used a mouse with a grip.
- The only MMO I play is FFXIV as of now, occasionally I go back to EVE online.
- What size monitor are you looking for, and what resolution? Screen type (IPS, S-IPS, TN, etc.), hertz (60, 120, etc.) This is where I need some help, all I want is something affordable while still looks good.
Thats about it, if theres anything I missed, let me know and I will be sure to clarify.
Steam : http://steamcommunity.com/id/halojedi360
