intel 2011v3 compatibility preferably out of the box support for the new cpu such as the i7-6850K or i7-6900K
at least 1x : fast m.2 slot for my main C: drive i was thinking of using Samsung 950 PRO m.2 ssd 512gb unless you guys know of something better ? does raiding 2 units make any actual "Tangible" difference for windows and gaming ?
at least 1x USB 3.1 Type C because id like to use that in the future in case something really neat comes along, i don't wanna have to go buy an add-in card
i am playing with the idea of getting a new power supply but my 850AE gold is working fine still
i need to hunt down the mounting hardware for 2011v3 for my swifttech apogee xl
i dont intend to spend an arm and a leg all at once with the ram but id prefer to use 16gb sticks, to max the system out over time 64-128gb ??what are good speeds and timings on ddr4??
I am planning on building a new rig at the end of this year or beginning next year. So, this is a waiting game for me (AMD, give me Zen allready in exchange for Euros).
You are going high-end, interesting. You might want to sleep over the mainboard then. Metal reinforcements were not needed for over 20 years, why now? On the 1080ti: After the performance difference between the 980ti and TitanX, I would say the 1080ti would not be worth it. Apart from that I do not even believe there will be one until the end of this year.
same thing but the 6 core instead of the 8 Total: $1306.96
is there a method of determining how many pci lanes that your build will use? i was thinking , one or two m.2 sata chips and one or two gtx 1080ti for 4k 60fps
MOST LIKELY just one m.2 and one gtx 1080ti tho
other than that , really thats the MOST this build will EVER POSSIBLY use i intend to take ALL NON ssd storage and place it on network
8x lanes each ? arn't they labeled as PCI Express 3.0 16x and 32x ?
the reason i wanna go a little bigger on the cpu, is twofold 1, i Really like larger numbers.... 2, this 2500k has served me well for like 5 years now the next cpu i wanna keep usefull for the next 5-10 years and im worried that itll be a shorter lifespan with the new dx 12 and better multithreading and stuff coming so rapidly
I have never seen a GPU max out PCI-e 3.0 8x slots (PCI-e 2.0 16x).
1) I am with you on that one (not simulation times though, make them as small as possible) 2) I am on an FX-8320 at 4GHz right now. I think I am good until Zen, after that... Games are only beginning on going multithread but even then it is just a bit slow.
Total: $1098.95 that price is obviously much more palpable .... but then im shrinking all the features that i dont neeeeeed but waaant because im a whiny little bitch....
I know that nothing part all too well. Could write a Blog about me doing nothing (and waste other peoples time with my time). I was writing a story on Wattpad, started a new one, went back to the first all while playing games at times and watching movies and videos. If that is what gaming is like today, those AnimalFarm guys are gamers aswell.
If Corsair´s LPX is anything like the LP series, it is good.
Then avoid Gigabyte boards. I had so much issues on the software side of things that I would never ever get or recommend any board from them.
Funny side note: I am listening to soundtracks now. Why watch a movie when you can listen to the soundtrack and imagine your own movie?
it seems paying more than an extra $700 usd for only 2 more cpu cores and 4 threads seems reallllly dumb especially when you think, $700 will be that gtx 1080 or like 80% or the 1080ti when it comes out...
