I am building my first pc and am having some problems. I have plugged everything in however when I went to turn the computer on only the motherboard led would light up. Everything else fans, cpu, cooler, wouldn't turn on. I will appriciate any help that anyone can offer me thanks!
Here are my parts below
CPU AMD FX-8350 4.0GHz 8-Core Motherboard Asus SABERTOOTH 990FX R2.0 ATX AM3+ Memory G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-1600 Video Card Asus GeForce GTX 670 4GB Case NZXT Phantom (White/Red) ATX Full Tower Power Supply Cooler Master 750W ATX12V
sabbertooth has 8 pin cpu power connector, somewhere above the vrm heatsink make sure you pluged the 8 pin or if you dont have, the 4+4 pin connectors into that.
Alright I figured it out. Here it was the top power connector. The manual says that the cables can only be placed in one way, but they will fit in any way yet only work if placed in the right way. Thanks to everyone for the help and for having me look closer at the top power connector.
