I have about 10,000 and want to make this either better but don't know how. Help please.
http://pcpartpicker.com/p/FpskVn
What are you doing with your PC? and why 3 980tis for 1080p displays, even if they are 144hz, you're just going to run into a ton of issues with that set up, and actually Fury Cards in crossfire are probably preferable due to better scaling, unless you're going to OC the 980tis in a custom water cooled set up
but I don't really think this is a real build
this looks like a dream build more than a realistic build. what could you possibly be doin with that amount of power anyway?
I would be trying to run all my games max video editing streaming My computer science work.
Well you only need to spend maybe, 3k on that, +/- some 4k displays
this is missing SSDs
PCPartPicker part list: http://pcpartpicker.com/p/rrK4rH
Price breakdown by merchant: http://pcpartpicker.com/p/rrK4rH/by_merchant/
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor ($374.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($29.99 @ Amazon)
Motherboard: Asus X99-A/USB 3.1 ATX LGA2011-3 Motherboard ($249.99 @ Amazon)
Memory: Crucial 16GB (2 x 8GB) DDR4-2133 Memory ($69.99 @ Adorama)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($49.98 @ OutletPC)
Video Card: XFX Radeon R9 Fury 4GB Triple Dissipation Video Card (2-Way CrossFire) ($499.99 @ Amazon)
Case: Cooler Master HAF XB EVO ATX Desktop Case ($94.99 @ NCIX US)
Power Supply: Rosewill 1200W 80+ Platinum Certified Fully-Modular ATX Power Supply ($207.01 @ Amazon)
Total: $2076.92
Prices include shipping, taxes, and discounts when available
Generated by PCPartPicker 2016-01-10 22:16 EST-0500
and this would be the 27" 4k display, though 40" 4k displays like a wasabi mango would be preferred, the 4k is just for video editing really, you'd still be gaming at 1080p if you wanted to do a surround set up, or you could do 4k on a single display easy
Fury Crossfire 4k
LG 27MU67 4k IPS free-sync display $500-600 depending on availability
http://www.google.com/shopping/product/17120560974970123385?lsf=seller:6136318,store:4186520405911227569,lsfqd:0&prds=oid:1523635370315146201&q=computer+monitor&hl=en&ei=uh6TVuHzN4XbmAGU14jYAQ
