I am getting this error when typing “cd Downloads” or “cd ~/Downloads” into my terminal. Also, I cannot use Nautilus to open downloads using terminal–as it is no longer an option is the menu of applications to choose from. I am also making sure that “downloads” is using a capital ‘D’ (i.e Downloads).
Manifolds
Perhaps I should just reinstall at this point?
I resolved the issue by simply installing another terminal. There must be something wrong with the link for the built in “konsole” on this version of Fedora. It is okay, as the default terminal was kind of trash. lol.
You didn’t include the text of the error message.
Unless you changed the shell you use, every terminal emulator you use will use the same shell. Bash, in this case. It’s the shell that processes the commands you enter in a terminal.
If you were not running as your user but, say, as root after using sudo or su, the commands would have failed because no “Downloads” directory exists in /root.
Thanks for the clarification–I have marked your answer as the solution, as it seems much more plausible for anyone else who might search the same question and stumble upon this post. Also, this coincides with the idea that launching Nautilus as sudo removes most of the directories from access. Imagine if I had just put two and two together. Likewise, I appreciate that response!
