im doing my test build and when i powered it up nothing appears on the screen and the cpu light by the memory is lit up (not flashing) what do i do?
both my 20 pin and 8 pin cables are plugged in; i dont get any image on the monitor. i also dont see any bent pins!
specs
Type|Item|Price
| | Total
| Prices include shipping, taxes, and discounts when available | $1708.14
| Generated by PCPartPicker 2014-09-23 22:07 EDT-0400 |
No you cpu is not DOA most likely.
I see that you have a 4790K haswell refresh cpu, paired with a Asus Maximus VI impact board which is a Z87 chipset board.
you need to flash the bios to the newest version, using usb flashback, without any cpu and ram installed. then it will work.
http://www.youtube.com/watch?v=JVvHwq3syqI
Further info´s
http://www.asus.com/microsite/2014/MB/New_4th_gen_Intel_processor_compatibility/#flashback
http://event.asus.com/2012/mb/usb_bios_flashback_guide/
worked like a charm! thanks a lot. i was really freaking out!
Ratzzz
#6
Wow ... I'm impressed again. Nice work.
