Good to hear.
I’m currently on Solus and really like the simplicity and practical looks of it. That’s not to say it doesn’t have its downsides; a few compromises but less than expected for a new, independent distro.
I’d say Solus is a nice “plug and play” distro but they gotta work on improving the software center. I just hope they don’t turn into the next Ubuntu because I’ll go back to Arch in a heartbeat if it ever happens…man I miss good old Gutsy Gibbon Ubuntu
Anyways once you’re comfortable in Linux, you’ll never go back. It’s just not the same feeling of having no boundaries. Your hardware will thank you.
you are right on all four points
nvidia announced dropping support for v304 driver last year
need a later gpu for nvidia legacy driver v34x
need kepler core (some GT/GTX 7xx) or better for v39x driver
Until OP gets an upgrade on GPU (even a GT710 would do) 16.04 'buntus or older Mint will have the right xorg version needed to keep going
Cinnamon would be slow on old hardware, even with ssd
If OP is determined on using Mint, MATE should be more responsive
(I would probably want XFCE on that age of hardware)
I’ve settled on Elementary. (Which I’ve learned is based on Ubunto). I’m primarily a Mac user so I love Elementary’s GUI.
It works great on my machine. Rock solid, no crashes. Very fast. I gave up trying to use Steam.
Solus was unstable and had weird graphical errors and random crashes. I liked it just as well as Elementary once I got it set up to look like a mac but sticking with Elementary for speed/stability.
I love it. Completely uninstalled WIn 7 (which feels slow as a dog in comparison) and direct boot to Elementary only now.
Most MATE implementations let you turn off the compositor, as does XFCE. More folks with weaker GPU’s should at least try that to see if they can live without the effects.
There are differences between window manager/compositor performance. Elementary uses its own. The OP’s settling on it speaks well for it.
