I would like to install and use NTT on CentOS7
I could not figure out yum so I installed git and used GitHub to aquire NTT
I am unsure if I actually installed it. I set my git directory to root and that is where it downloaded the NTT files.
I have no clue how to launch this tool and the api instructions seem of no use.
I would like to use this to bulk convert files to dds after they have been processed
This is more of a learning experience because I am aware that I could just install gimp.
So questions I have
How do I know if I installed the program?
How would I install it with yum?
If I installed it how would I know how to launch it?
How do I use the program is a question I have as well, but I feel that’s something different all together. But help with that is appreciated after the other items are addressed
ps. Thanks for any time spent responding
Sorry for errors I sent this on mobile.
pps. If anyone cares I ultimately wanted to use this to help mod Morrowind textures. And also play with texturing compression
With the help posted by sgtawesomesauce, I was able to install NVTT
I am unsure if the version in yum was up to date as the one on git has more recent changes.
I discovered how to access the different tools just by typing in the names below.
I managed to convert 2 files to dds format but only one at a time. I wanted to try and do a bulk
nvassemble -Create cubemap DDS files from multiple images.
nvcompress -Compresses the given infile into a dds file.
nvddsinfo -Shows available information about the DDS image file.
nvdecompress -Decompresses the given infile into an image file.
nvimgdiff -Able to show the difference between the two provided images.
nvzoom -Scales the image file with support for scaling and some filters.
This project is really bulking up, I want to try and enable cuda, write a script to help make using the tools easier, update the version possibly.
