Hi, I need some help to improve my rig.I want to be able to play games at around medium-high.Mainly i'll be playing battlefield 4, minecraft, ESO, DayZ, DayZ Standalone I can't go too high on the price but what lets me play whats coming up soon, it's all good.
These are my current specs: http://pcpartpicker.com/p/1UYcI
if you are having your parts delivered- well if you can get a better GPU as the 6670 is "2 generations" old right now that would be the best bet. If you dont mind playing them in low res it will work but anything thats HD will destroy this. Id say spend less on the CPU, get a athlon 750k or something similarly priced, and put that money into a hd 7800 or higher as it comes with free games or one of the r5s when the game deal transfers over to them.
If you are able to go to microcenter- I would say get one of the new gen apus, they perform better as they have a newer architecture. And use the money u save on the bundle to put that into a better GPU, see what the person whom helps you (and please atleast let someone put their tag on the stuff you are getting as they get commission for it and they dont get paided the best anyways) im guessing they will push an hd 7800 or a hd 7900.
look for a nice cheap 7870, r9-280X or 7950, that's probably the only upgrade you really need for decent framerate on high settings on the games you listed, BF4 (assuming you will be playing multiplayer) might struggle a bit on that CPU but that would need a new Motherboard and CPU if you really wanted to upgrade, and that ain't cheap.
