OK so i build a new computer a last Thursday 1/23/14 And i kept My hard drive from my computer but know i keep blue screening I haven't check them all but i have gotten two blue screens so far: 1a and x (insert some 0s) 24 I don't know why i though it was just breaking itself in but its just getting annoying now.
MY rig:
FX-8320
MoBo: MSI 970a-g46
RAM: Crucial Ballistix Sport 8GB (1 X 8GB) DDR3 1600MHz
GPU: GT 430 (I kept it from my old rig upgrading soon)
From what im seeing, this motherboard isn't recommended for the 8core processors. For a while they weren't even on the support list. It only supports a CPU with max power consumption of 125w which is pretty much any of the FX-8xxx series. You're likely pushing that mobo too hard with that cpu, should always pay a little more for a good mobo rather than use that as a area to save some cash. =/
1) using a low end mobo with hungry 8 core = disaster
2) could be anyone of your seagate hdds
>>. if your old setup had your sata mode as IDE - may want to check that its set to that in the bios. If its set to AHCI and you are trying to boot into a windows install that has been done with it set to IDE, you'l blue screen til the cows come home.
3) your psu isnt up to scratch
4) you made an error somewhere in your building process - loose connection so forth.
Wait so I need a new Mobo? Is there any other way it could be something else? I mean i don't think my parents are going to get me a new one. (i think my return date has expired as well)
you should probably try and do a clean install of windows. then install the drivers for everything. that's most likely your problem. (example) you can't take something that thinks it's a Pentium 4 rig, and shove it in an i7 machine and expect everything to work right. that's what all your software and drivers are configured for on that windows install right now.
That motherboard is a piece of shit and your putting a super power hungry processor on it. I'm not even sure it has the updated bios that "supports" the 8320/8350. (I put the " " in there because nobody should ever use a MSI AM3+ motherboard)
