Guys I need help, my build is coming to a close ( http://pcpartpicker.com/user/Emoreignz/saved/1Me7 ) but I can't seem to figure out this last part. My case has 4 usb 2.0's and an SD cardreader which apparently uses usb 2.0, yhe problem is from what I can tell my motherboard (Asus Maximus VI Hero) only has two sets of pins to plug into located on the bottom part of the board. Two of the usb leads have two cables running into them so I assume that they are both from the front panel usb. There's also one lead with only one cable which I assume is for the SD card reader.
Again there are only two sets of pins on the mobo for usb 2.0 but I need three. Am I missing something or is there something I need to do or what? My motherboard did come with what appears to be an extensionfor usb 2.0 although I don't think it could be made into another port.
Thanks in advanced,
~ Emo
P.S. I'm 14 and this is my first build so Idon't know what every minute part is called :/
