Hi guys, im a noob and i need some help. So, i just bought a new ssd and i was gonna put win 7 on it and put it in my laptop, but i was having trouble booting from it. It was a win8 laptop (samsung series 3 np350v5c-t01us). so i went into bios, disabled secure boot, loaded win7 from a dvd (with .iso download) and started it up. it seemed okay, but something was wrong with the .iso i guess cuz it was acting funny. so i tried to boot acronis to wipe the ssd, and it wouldnt let me. eventually i wound up putting the boot setting to "legacy mode" and now i just get an error saying "mbr error 1, press any key to boot from floppy". i cant even access the bios now and my old hdd wont boot with win8 on it.
Can you boot into the BIOS with no hdd/ssd installed? You should be able to.
If you cant get into the BIOS no matter what you try, open it up and take out the cmos battery for a minute or so. Then try again.
Could always try a linux live disk and boot from that as well.
No i cant, even without one. I tried taking out the cmos and ubuntu, ubuntu started up, but i could do anything with it.
hmmm put the hdd that came with it back in, & send it back for RMA if you are still in the warranty period.
thanks ill give that a try
I did this once with an HP laptop. The windows 8 fastboot was so ingrained in the laptop that it wouldn't even go into recovery. Had to get it repaired.
I feel like less of a man because of it,
Your disk is set to GPT most likely and you need to set it to MBR most likely. if you do this it will wipe all your data on the disk.
when installing Windows 7...
1. Click advanced install
2. When you see the option for formating, create new etc click "shift + F10
3. a command prompt window will appear
4. type "diskpart"
5. type select disk
6. select your boot disk (usually 0) by typing "Select disk 0"
7. type clean
8. type convert MBR
9. type exit
10. proceed with install
again if you do this you will loose all data on drive! now try it.
EDIT: Nevermind I missed the part where this was a new SSD. It should be formatted MBR. However the second option may work.
Just use windows 8 and use Startisback is your best bet. If you do this then follow my steps but type "convert GPT" instead.
i just hit esc and it list the bios boot stuff and the recovery. :P Give it a go
Why the hell would you want to use MBR with a UEFI accelerated BIOS and WIndows 7/8? MBR is slower than GPT for boot up and doesn't recognize drives larger than 2TB.
Hit esc. should give you a menu related to bios stuffs in win8, dw about the techies xD works for me.
He wants to install Windows 7. You will not see that much speed increase with Windows 7 and GPT. Also, I highly doubt his new SSD is that large. When I read this at first and answered the OP's question I thought their may be a compatibility issue. So he could try to format it either way and try it out. However I think I read his post a bit incorrectly and missed some details a couple times.
