i was trying to flash an unofficial release of AOKP om my galaxy tab 3 and i guess i didnt understand instructions and accidentally formatted my internal storage and bricked it. it wont boot and i cant access recovery or odin mode. its just been stuck on a screen that says "samsung galaxy tab 3"and i cant turn it off. is there a way of saving it or is it gone forever :( its a galaxy tab 3 sm-t310 lt01wifi
Well I think you soft-bricked it soo you can probably fix it. I'll post if i find anything good that may help.
EDITS
Cool thing on xda: http://forum.xda-developers.com/showthread.php?t=1133590
Other thing. http://unbrick.itcse.com/unbrick-soft-bricked-samsung-galaxy-tab-3-lite-sm-t110/
There is so much good stuff just look this up "samsung galaxy tab 3 soft bricked"
i found a thing online called a jig and i bought one from a local phone store for $5. it put my tablet in download mode! ill tell you my results when im finished
If you can see the boot logo you aren't bricked. You simply need to get a ROM on an sdcard and get back into recovery. You probably aren't following the instructions correctly. It's nearly impossible to hard brick a phone now days. Find a back to stock guide on XDA for your tablet(make sure its YOUR MODEL and carrier if applicable) and go through the guide step by step.
i tried to flash stock samsung rom and it says "cant mount /data" i dont know what to do
done.
just bricked my Galaxy s5 active.
no post. no leds.no charge status.
and just 5 minutes ago
