I am kinda in a pickle because I have tried every trick I know and still the battery life is horried.
I just aquired a Lenovo P1 Gen 6, w/h the I7 13700h and RTX 2000 ADA and 1600P 165hz screen.
My previous notebook was a X1 extreme gen 3 w/h a 10750h and and a 1650, and I can get like 3 hours on that one, although that has a 80 wh battery and this has a 90 w/h battey.
This one, no matter if I disable the GPU, set it to the power saving offset, set refresh to 60hz, I loose about 1% per minute. Battery is at full health and everything is set to use the IGPU.
The whole reason I bought it is because I thought it was supposed to extend battery life with it’s E cores. Bios is on latest, all drivers are installed from lenovo vantage.
Heres the kicker, I get DOUBLE the battery life on Cachy OS, with the power savings offset enabled.
I tried setting the affinity to cores 12-19 on all the top processes, but still haven’t seen any improvement.
Anyone have insght on why this is happening? Any way to correct it?
I would daily linux if I didn’t need visio and a few other microslop apps.
From what you’ve shared the only thing I can think that could be causing this with winslop 11 would be an application running in the background and completely killing your battery or an application is still ping the discrete GPU .
I’d recommend the debloating, your Windows 11 install , if you need a tool, just let me know
Couple things to check. Windows in general likes to ignore that you are on battery for updates if you boot on wall power. Check you are booting cold on battery for any troubleshooting to avoid random drain from background updates. This one headache on win laptops is why many of us moved to Linux or mac. I’ve been burned even with wifi off because win had previously downloaded the update and was staging it.
Make sure you have the latest intel power management drivers from Lenovo, the easy way to do this is just grab the Lenovo vantage or system update app and go ham on updating drivers. Use the Lenovo specific windows power plans for best results since most have either a power mode feature that toggles in firmware that has to coordinate with the windows power plan. I think the P series has a ‘cool lap’ mode you can check in the bios or manual for.
I use Lenovo as my daily dual booting and I don’t think the out of the box fresh windows install without their custom software is a good experience (opposite of asus…). Outside of vantage getting bloated recently they have done a good job optimizing their software stack to be better than the fresh win install.
My work-laptop likes to default to the high-performance power plan which then slashes the battery life from 9 hours down to 50 minutes while scorching the table (makes for a nice coffee-warmer though).
Have not looked into permanently fixing this just yet, just manually setting it to normal/auto.
As a comparison, I use Fedora Silverblue (immutable images) called Aurora by Universal Blue on my Thinkpad P1 Gen 5.
Sorry, never tried Windows. I love unboxing a new laptop, and immediately booting the IODD drive on Linux to format. Ive never seen Windows 11 since it was released. Neither has my kids nor wife, as we’re all Linux (ur switching, right? Right?).
Default install, no driver or iGPU changes (it defaults to everything on iGPU, have to explicitly set ENVs to use dGPU).
It’s the highest end 12900, 6P, 8E with 4K and LiquidMetal and 80Whr battery.
With HDR disabled, and keeping screen really low brightness, I get about 6-7 hours of coding (non local Ai on the A5500). Power set to Balanced. That’s VSCode, Terminal, and local web server testing.
Heavy browsing is a whole nother ballgame as I have like 90 tabs across 7 windows (I use the virtual desktops setup with 3-finger slide like macos, as well as Cube). Browsing I only get 2-4 hours. Just pure YouTube and browsing in Brave.
JellyFin can stream 4k about 4 to 5 hours. I can almost watch two movies, but not quite.
With HDR enabled, I can only watch JellyFin about 2 hours with brightness 50% for 4K HDR - not even a whole movie. YouTube HDR 4k kills the battery in about 90m.
Ps, my Thinkpad P1 Gen 1 4K 8000 series gets about 9 hours of coding on the 80Whr with PopOS. I miss those days.
