Help: Forbidden Router and virtual NICs to other VMs on host device
Hello, please bear with me as I don’t really know how to ask my question. I am building the forbidden router without having first attained full pfsense enlightenment. I don’t really know how to word my question so I’ll just describe my situation. The router is running with pfsense in a proxmox virtual machine and a PCIe pass-through of my x550 is working so pfsense has full ownership of the WAN and LAN port. I also went and configured unbound to forward DNS over TLS to Quad9 which I would like to be the final link in my DNS chain. Now I want to get two pi-holes up and running to provide two groups of filtering which I plan to do through NAT aliasing so I can hand out the aggressive pi hole as the DNS server to cool people and the normies can get a less aggressive pihole with their own web interface that’s separate and isolated from anything to do with the router. Sounds easy enough but I’m confused about how I should set up the virtual NICs for the VMs.
What I want to happen is for the two pihole VMs or really any VM to appear as though they are plugged directly into my network switch with max throughput to the pfsense VM but actually be directly talking to the pfsense VM, not going out the management interface physical NIC, to my switch, and back up the wire to the x550 LAN port. Since I gave full ownership of the x550 to pfsense, I think I want to create a new virtual NIC in proxmox, assign that to pfsense and then I don’t know. I don’t what settings to configure for the NIC or how to make sure the other VMs send their traffic over that and not the proxmox management physical NIC. I would assume I could configure it in pfsense as just another LAN port in the same subnet? I’m not interested in VLANs or any segmentation of the network, quite the opposite, I want my VMs and devices to be as if they are sitting on the same switch on the same network. I also can’t add more physical NICs to the setup and wouldn’t really want to since that somewhat defeats the idea of getting the fastest possible connection between my virtual machines and it just seems unnecessary for a signal to need to travel outside the box and back into it when I should be able to establish some link. And it’ll be more rad this way which is of course an important consideration
You could create the virtual interface, add it to pfsense and bridge it with the LAN interface
Parhaps SR-IOV?
At least on esxi, what you described is essentially how things work when you passthrough SR-IOV virtual functions to the pfsense VM rather than the whole X550.
I’ve got no experience with proxmox so I may be off base here.
Running a single pi-hole in a separate proxmox vm should be sufficient.
  • Install pi-hole,
  • Make sure all of your devices can access pihole,
  • configure pi-hole to connect to existing unbound (there are also instructions to run unbound next to pi-hole - FYI)
  • add firewall rules that block DNS queries from any device but unbound.
Pi-hole has a group management feature that should allow you "to provide two groups of filtering ".
I added vmbr0 to my pfsense vm in proxmox then in pfsense added that virutal network port to interface OPT2. I then created Bridge0 in pfsense with LAN and OPT2 which took out my network for two hours. Turns out I had to unplug my management ethernet because I guess I created a loop which pfsense didn’t like. Now all my (existing) VMs and the hypervisor are talking, can be accessed from my LAN and can get to the internet…
Interesting new problem though, I can’t get new VMs to access the internet… I tried adding a second bridge, vmbr1, to pfsense and the new VM but nothing… Pfsense shows both interfaces as up but no dice. Are there additional considerations for either the interface or bridge configurations in pfsense? I did try to rtfm but I apparently haven’t found the correct section…
You don’t need to make a new bridge interface for each VM, just give them all the same one and it will work.
