My current computer is getting old and sluggiish to the point where it has become a bit of a problem. I would like to build myself a computer, however I haven'tdone anything like it before. I'vre done a bit of research andhave now come up with a parts list. My main goals for this setup would be gaming. As a newbie, I would greatly appreciate any recommendations on how to improve and what I could expect this setup to run.
Link to the parts list: http://pcpartpicker.com/p/179nS
As a side note I don't plan on over clocking (yet)
http://pcpartpicker.com/p/17a7K
seeing as you can spend that much more i would reccomend (in this order):
1. a better motherboard (asus m5a97 r2.0, m5a97 evo/pro, or any 990 chipset (but i wouldn't reccomend asrock)) check some of these out generally more phases = better (not always though)
2. get a name brand psu (that looks ok, but i'd look for a seasonic or maybe corsair)
3. go up to a 7950
4. go up to a 8320
i would choose what to change in that order, based on how much you really want to spend
Yeah seasonic or corsair XFX even cooler master
i would go with this case instead get it from NCIX instead of newegg cheaper but for 1 day only i would buy that now if i was you
http://us.ncix.com/products/?usaffiliateid=1000031504&sku=78227&vpn=Arc%20Midi%20R2&manufacture=Fractal%20Design&promoid=1283
PSU
http://www.newegg.com/Product/Product.aspx?Item=N82E16817171068
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151095
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151119
http://www.newegg.com/Product/Product.aspx?Item=17-139-048&Tpk=17-139-048
