So I’m thinking push pull on the radiator with fans mounted in the 50mm portion of the bottom left picture. I wonder if thats just too close and will cause restriction.
Probably overthinking it.
You guys are probably going to cringe but I ordered a very expensive amount of corsair RGB puke for this one.
My thinking on this isnt for the radiator cooling aspect but for the increased airflow on the system. If its wrongthink then I’m happy to entertain ideas.
I have 6 total RGB fans that will be mounted as I see fit.
I want to keep positive pressure to reduce dust.
I want a 360 to fill that side mount for intake.
I can rob fans from my current build/laying around.
The rest I havent thought about, input is welcome.
Petg is really easy to bend by hand, i didn’t even open the second pack i bought in case of fuck ups. I probably spent 2-3 hours at most on the tubing of my fx build.
Side note, the insert i bought was a different brand than the tube and barely fit in the tube lubed up
